Return to the readme file.
OMAX / MAXIEM Intelli-MAX® Premium and Standard Software System Requirements
Contents of this page
Warnings
Warning:
For replacing the computer on a machine tool (not the office PC), OMAX strongly recommends buying a pre-configured replacement computer directly from OMAX/MAXIEM Waterjets.  This is the only configuration that Technical Support will support.   OMAX is not equipped to support computers purchased elsewhere.  The Intelli-MAX software has specific hardware and configuration requirements that the computer must meet in order to be compatible for running an actual machine.  (This statement does not apply to off-line / office PC support)
Warning:
With the exception of a few special cases, the premium version of the OMAX Intelli-MAX software will not operate a non-OMAX machine tool, including most MAXIEM waterjet machines.  For MAXIEM machines one must run Intelli-MAX Standard, unless a premium upgrade has been purchased.
Warning:
It is generally recommended to run on the latest version of Windows operating systems using 64 bit unless there are extenuating circumstances that force otherwise.   Periodically, OMAX will discontinue software development for older operating systems in order to not be boxed in by their limitations.
Important:
Future software upgrades may require the purchase of additional hardware upgrades in order to allow running of the software.  For example, in the past when the Windows based controller was released to replace DOS, the software was free to OMAX customers, but it required the purchase of a new Windows based computer and some additional electrical components in order to install the free software upgrade.   As support for older versions of Windows diminishes or is dropped, it will likely become necessary to upgrade select hardware components, at your cost, in order to continue to use software updates in the future.  Also, some hardware (for example the Precision Optical Locator) may not be compatible with all operating systems, and may require component replacement when computers or operating systems are upgraded.
Important:
This document is current as of the time it was last reviewed, which by the time you read this may be some time ago.  Always check for updates at omax.com/support, to ensure you are working with the latest information.
Ideal System
The ideal system for running Intelli-MAX Windows based software, is the following, or better:
** 3D OpenGL hardware acceleration is only required to use the 3D Path Editor, JetSimulator, OMAX Intelli-CAM, and future 3D utilities.  It may also be a requirement for LAYOUT and Make in future software updates.  OpenGL is a registered Trademark of SGI.  Please note that Intelli-CAM (an OMAX-only product for 3D file conversion and pathing) has significantly higher system requirements, especially for the video card, than the Intelli-MAX software.
Minimum Requirements
This is not what we recommend, but here are the absolute Minimum Requirements to run the Intelli-MAX Windows Software on an off-line PC (But not ideal, and not on a machine tool.):
Notes on using Touch
The OMAX software has some built in features for supporting some touch displays and touch paradigms.  However, there are many different touch devices out there, and many of them are not supported.
As a general rule of thumb, relying on a touch as the interface is not recommended.  A standard keyboard, monitor, and and mouse is the preferred method of input - especially when working with CAD functionality.  Touch, then, in some cases, can be used to augment this functionality for special purposes.  (For example, the optional touch display that is available for some machines, can be used for jogging and other simple tasks.)
Notes on using high DPI displays
The OMAX Software should run fine on most high DPI (Dots Per Inch) displays in Windows 7 and newer.  However, on some custom setups, especially when using the OMAX 3D Path Editor, one may experience the "Zoom Cursor" and "Pan" commands drift inappropriately.  If this occurs, either use alternate commands (such as Zoom Window), or try a different DPI setting in Windows.  Generally speaking, the standard font sizes provided by Windows should all work fine on Windows 7 and newer.  Unusual custom font size settings that are nonstandard will usually work, but not always.  For troubleshooting information, search for "High DPI" in the OMAX Interactive Reference. (For MAXIEM users, the OMAX Interactive Reference can be downloaded from omax.com/support)
Notes on specific and alternate operating systems
(Older Windows, DOS, Mac, Linux, 64 bit, etc.)
64 bit Windows
For Office / Off-line PC's:
The Intelli-MAX software has been tested to run under both 32 and 64 bit versions of Vista, 7, 8, and 10.  It will run on offline PC's fine on any of these operating systems.
For actual machine tools:
64 bit is supported for all 9-axis USB card equipped machine tools.  This includes all machines under the MAXIEM brand, and most (newer) machines under the OMAX Brand.
Important:
5-axis customers: For those older OMAX Machines that have the "5 axis USB box", it is necessary to upgrade to the 9 axis USB card, along with an additional adapter that adapts the signals from this new card into the older 5 axis style.  Please check with OMAX Technical Support for the latest information on this (techsupport@omax.com).
OMAX DOS customers: For those with the very old DOS based OMAX Machines, upgrades are also available, though that will require computer and additional hardware purchases.
OMAX Precision Optical Locator customers, please note that the older USB cameras are not 64 bit compatible.  As such, you will need to replace your camera with a newer one that is 64 bit compatible.  OMAX has these available for you, but it is a cost to consider.
Windows 10
This software has been tested and verified to work on Windows 10.  64 bit is recommended, as OMAX intends to stop developing software for 32 bit versions of Windows sometime in 2018.
Windows 8 / 8.1
The Intelli-MAX Software runs fine under Windows 8 and Windows 8.1 - though OMAX intends to stop developing software updates for it sometime in 2018.
Windows 7
The Intelli-MAX Software runs fine under Windows 7 - though OMAX intends to stop developing software updates for it sometime in 2018.
Windows Vista
The Intelli-MAX Software runs fine under Windows Vista - though OMAX intends to stop developing software updates for it sometime in 2018.
Windows XP
Support for Windows XP ended with version 21.0 patch #4.  Older versions of the Intelli-MAX software can be found at omax.com/support.  If one needs to run software newer than 21.0 on a Windows XP equipped machine, it is first necessary to either upgrade the operating system or replace the PC with something newer.
Windows 2000
Support for Windows 2000 ended with version 19.  Older versions of the Intelli-MAX software can be found at omax.com/support.  If one needs to run software newer than 19.0 on a Windows 2000 equipped machine, it is first necessary to either upgrade the operating system or replace the PC with something newer.
Windows 95 / 98 / ME / NT
These operating system require Version 9.0 of Intelli-MAX, or older.  Older OMAX software can be downloaded from http://www.omax.com/support.   Note: There is no MAXIEM solution for Windows NT and older.
DOS
DOS OMAX software is available, and can be downloaded from http://www.omax.com/support.  It is significantly less capable than the Windows version, and is recommended only for legacy purposes.  There is no MAXIEM solution for DOS, though tool paths created with this older software will run fine on MAXIEM machines.
Existing DOS customers are encouraged to take advantage of upgrading to Windows by replacing the computer, and a bit of additional minor hardware.  Complete kits are available from OMAX.
Macintosh
The Intelli-MAX software can be run on many Mac based computers using the Apple product Boot Camp or other similar utilities.  Below are some notes on these options.
Note: What follows was written considering OS X Yosemite Version 10.10.3 in May of 2015.  The information here may not be completely accurate for other versions, though for the most part it should be.   Do your own research before committing to a solution for your particular needs.
Important: The information here is intended for offline running of the OMAX software.  Do not attempt to use a Mac to run a machine tool.  This is not a supported configuration.
The Intelli-MAX software product is designed to run on Windows, and not designed to run on a Mac.  In order to run on a Mac, therefore, it is necessary to install Windows onto the Mac.  There are several strategies on which one can do this:
If Mac support is important to you, please let us know because your feedback helps us set future development priorities.  Email softwareengineering@omax.com with your requests.
Linux
The Intelli-MAX has been tested running the OMAX software using Wine under Linux (in particular under the Ubuntu distribution.) Here are some notes on the tests:
If Linux support is important to you, please let us know.  Email softwareengineering@omax.com with your requests.
Android / iOS / Windows Phone / SteamOS / Amiga / Other
None of these are presently supported.  If such support is important to you, please let us know.  Email softwareengineering@omax.com with your requests.
Configuring a computer to run as a machine tool
Copyright © 2003 to 2018 OMAX Corporation All Rights Reserved.
