(Newest features
listed at top)
Version
32.0, Patch #8
Changes
made to Intelli-MAX Global since version 32.0, Patch #7, which was
released on 2/5/2021
- Changes have been made in other brands. No changes have been made
in this patch for Intelli-MAX Global.
Version
32.0, Patch #7
Changes
made to Intelli-MAX Global since version 32.0, Patch #6, which was
released on 7/13/2020
OMAX Monitor
Enhanced data collection
- Automatic
update of data collection software
Version
32.0, Patch #6
Changes
made to Intelli-MAX Global since version 32.0, Patch #5, which was
released on 1/17/2020
Device Driver and Firmware
Bug
Fixes
- Fixed a bug in MAKE where
material thinner than 0.25 in. (6.35 mm) was being cut at incorrect
high speeds. Cutting times are now more accurate for thin material and
the cutting speed profile is much smoother--especially when using tilt
forward in small corners.
- Updated links for OMAX support website.
Version
32.0, Patch #5
Changes
made to Intelli-MAX Global since version 32.0, Patch #4, which was
released on 7/7/2019
General
- Updated external reference used in setting TimeStamp for signed
files. This ensures that digital signatures in the software
distribution are all up to date. (Digital signatures are used
throughout the software to help ensure that when it is installed, it
has not been corrupted or tampered with; digital signatures also reduce
the chances of antivirus programs detecting false positives and
rejecting the installation or files within our software.)
Bug
Fixes
- Corrected Language-specific web site links. (For some non-English
versions of the software, links to OMAX web sites were pointing to
older out-of-date locations.)
- Fixed an issue in MAKE where
the timers and counters were not tracked correctly when the path was
paused. Previous to this bug fix, not all running hours were being
counted in some instances, which could cause confusion about the actual
runtime of the pump, abrasive, and other accessories.
the
delay for the terrain follower at the beginning of the path was not
sufficient when Keep the pump on
between paths when multi-cycle cutting
was selected in the Event and Relay Timing tab.
a
delay between "end of cut" and traverses was missing in some cases.
This fixes a case where the jet may not have fully cooled down as the
traverse starts, potentially resulting in a blemish on the part at the
start of traverses on machines that do not have dual on/off valves,
machines with slow responding on/off valves, or when using “brittle
mode” to turn the jet on and off at the pump.
Version
32.0, Patch #4
Changes
made to Intelli-MAX Global since version 32.0, Patch #3, which was
released 6/17/2019
Bug Fixes
- Fixed a critical
bug in MAKE where
finishing a path would cause the interface to freeze and the pump to
remain on, preventing any more control from the application.
a
This may cause the waterjet to turn off while already traversing.
the pump turned on at the end of a drawing that had no cutting
entities.
Version
32.0, Patch #3
Changes
made to Intelli-MAX Global since version 32.0, Patch #2, which was
released 4/2/2019
MAKE
- In the OMAX Path Control Dialog (appears when you click Begin Machining), the tooltip now
explains that double-clicking the progress bar displays the path's
progress in a large window. (This is helpful if you want to view the
progress from a distance.)
Scripting
- Added a sample script to demonstrate how dimensioning or other
information can be included for machine operators.
Bug Fixes
- Fixed the spelling of the word “transferring” in one of the MAKE menu items.
Version
32.0, Patch #2
Changes
made to Intelli-MAX Global since version 32.0, Patch #1, which was
released 3/18/2019
General
- Trademark-related
updates were made.
Version
32.0, Patch #1
Changes made to Intelli-MAX Global since
version 32.0, which was released 1/21/2019
General
- Modified the “Check for updates” feature to properly notify users
of software patches in addition to major version number changes.
Bug Fixes
- Corrected translation issues (missed strings) and decimal/comma
handling in foreign languages.
- Fixed a
bug in MAKE where very slow cutting speeds (very thick and/hard
material) could have caused a perceived delay before the pierce.
- In LAYOUT, fixed the
spelling of a settings file associated with the Advanced Tool
Offsetter.
